That is POSSIBLY true (I don’t think for one second that it is true, personally), but I’ve never seen any official verification of it. I have seen PLENTY of early ETAs go bad.
But basically this is saying that all original ETAs found in 1991-1993 cars are good wiring, and all facelift ETAs with smaller plugs are bad wiring. However, I’ve certainly seen early (pancake) ETAs with bad internal or external wiring, so I DO NOT think Victor is correct, at least in regard to the V-8 ETAs as found in the .034 and .036.
Also remember that the external and internal wiring is NOT the ONLY issue that goes bad with ETAs. The gears and potentiometers inside (mechanical parts) also degrade with time and use, and cause failures.
Again, it’s a MUCH safer bet just to get an ETA made after 2000. Not only will the wiring be a non-issue, but the internal components will be newer, as well.
The caveat is that with any used part, you are always taking a gamble.
I was able to buy a near-new (500 miles) ETA with ASR when I did my M104 top-end rebuild some years back (it’s described in the M104 Top End Rebuild thread).
@gsxr found it on eBay and pointed me toward the seller, and I Bought it for a reasonable price. You can see from the photos that the internal wiring of my ETA on that M104 was toast (smaller/late connector).
